Hi!
I've built an WinForms app using the Infragistics NetAdvantage in the trial version. Using theese resources, I've built a release (executalbe + ig libraries) and distributed for testing on a few PCs. Everything went fine, the app worked ok.
After buying the NetAdvantage cdkey and upgrading my application (with version utility) i've built another release (executable + ig libraries) , but this time it works only on my pc (where ig is registered) and on another pc wich didn't had NetAdvantage trial installed.
Could you give me a explanation, or some directions on how should I corectly deploy my application ?
Thanks!
I have noticed that you have posted the same question here: http://community.infragistics.com/forums/p/46526/250372.aspx
If it is possible to continue this duscussion here. As the other forum is about grids.
Thank you.
Stefaniya
Let me know if I can help you with something.
