I have an adjoining Outlook (2007/2010) region with a UltraCombo on with the DropDownWidth set to a greater width than the control itself. The combo is configured to resize all columns.
After upgrading to version 2010.3 the columns doesn't get wider than the control not even if trying to change size in runtime. This is a showstopper for upgrading.
If the UltraCombo is no longer showing all of the columns, then that would be a bug in the control. This behavior has not changed as far as I know. Can you provide a sample project which demonstrates this behavior? I tried it out and it works fine for me.
Hi, any news about how to Set the autofit to extend last column to the combo. In Version 2010.2 was working perfect. In 2010.3 i have to set cboPlanFee.DropDownResizeHandleStyle = DropDownResizeHandleStyle.VerticalResize in order to see all the columns fitted in the layout.
I don't understand your question. You don't have to set the DropDownResizeHandleStyle in order to set the DropDownWidth property.
Hi, We have issue with the DropDownWidth. The only way we can make it work is set the:
DropDownResizeHandleStyle = DropDownResizeHandleStyle.(other than none),
But the DropDownResize style is something we don't want to use. We want to have DropDownWidth work
without setting the ResizeHandleStyle.
Please inform us about the fix and how to update it.
Ing. Vazquez
Hello Erich, I was able to reproduce your issue so I have created the following case for you: CAS-54911-QNVQ3K. I will update you via the case as soon as I have more information for you. Thank you for using Infragistics Components.
