Hi all,I have a problem with an UltraCombo. The combo is placed on a usercontrol looking like this:
It's part of some webbrowser thingy and used for history navigation.Now when I open the dropdown (regardless how many items there are actually in) it looks like this:
How can I deal with the dropping down list to size it properly?I used PreferredDropDownSize and max/min dropdown items but without result.
Without the resizer and without setting the DropDownWidth (which I did in order to see anything) the dropdown width is exactly the size of the dropdown (the thing with the down-arrow to click) which is only about 35px.
Is there a way to set the height of the dropping down list?
Thanks a lot in advance,best regardsAndy
Alex, Thanks for letting me know the results.
PS - We are officially logging this issue with Development as per Mike Saltzman's recommendation. You will soonrecieve details about this in your private support case with us.
Hi Francis,
Yes, I do see the updated versionless DLLs now. Thank you very much for the hint, I really appreciate it. It was, clearly, an oversight on my part.
Alex
Hello Alex,
I tested the Service Release installer for NetAdvantage for Windows Forms 10.3.20103.2067. It did replace the zip file in the C:\Program Files\Infragistics\NetAdvantage 2010.3\Windows Forms\Version-Free folder. The new zip file contains dlls wityh version 10.3.20103.2067. Are you not seeing the same?
Mike,
I also would like to second the question regarding updating the verionless DLLs.
Thank you and have a nice day.
Hi Mike,thanks a lot for your help on this problem, I really appreciate your support.Is it possible to stay on track regarding this issue?Just to know it is fixed so I can implement whatever is necessary?
Regarding the service release, my superior downloaded Winforms and WPF release, he said there were no other downloads. Installing the release upgraded my current installed Infragistics versions to the new one, leaving the version-free dll's as is.
Thanks again and have a good week,best regardsAndy
