315
Hiding the header in UltraListView
Simple as it is, I can't find how to hide the header in this UltraListView, which is the right box in this work-in-progress screenshot:
http://www.softwaremotif.com/technical/images/MyFindings.jpg
I have suppressed all header properties I can find as well as made the header 0,0 but I still have the grey header container at the top.
Any comments much appreciated.  Thank you!
  • 209
    Suggested Answer
    1. Define a class that implements IUIElementCreationFilter:
      class NoHeaderCreationFilter : IUIElementCreationFilter
          public void AfterCreateChildElements(UIElement parent)
              if (parent is UltraListViewUIElement && (parent.Control as UltraListView).View == UltraListViewStyle.Details)
                  UIElement header = parent.ChildElements[0];
                  UIElement list = parent.ChildElements[1];
                  Rectangle rc = Rectangle.Union(header.Rect, list.Rect);
                  list.Rect = rc;
                  rc.Height = 0;
                  header.Rect = rc;
          public bool BeforeCreateChildElements(UIElement parent)
              return false;
    2. Set your UltraListView to use this class:
      myListView..CreationFilter = new NoHeaderCreationFilter();
  • 740
    I ran into same problem and hopefully it will be a new feature in one of the next releases.
    In the meantime i followed this workaround to hide the header with this code:
            lstInfo.View = UltraWinListView.UltraListViewStyle.Details
            With lstInfo.ViewSettingsDetails
                .ColumnHeaderStyle = HeaderStyle.Standard
                .ColumnHeaderBorderStyle = UIElementBorderStyle.None
                .ColumnHeaderAppearance.BackColor = Color.Transparent
                .AllowColumnSizing = False
                .AllowColumnSorting = False
            End With
    Obviously it still takes up de used space.
    Perhaps it's helpfull for others.
    Jacob Iedema
  • 69832
    Assuming you are using the 'Details' setting of the View property, you cannot hide the header. Going by the screenshot it would appear that you only have one column, so you should use set the View property to 'List', and if you want only one column of items, set the UltraListView.ViewSettingsList.MultiColumn property to false.
