125
UltraGrid RowScrollRegions
I have questions regarding rwo scroll regions.
I have one grid where in I want to split the grid into two halves and display active rows on top and inactive one on bottom section (bottom section is preferable grayed out).
I am trying to achieve this with rowscrollregions but seems the different regions display same rows in each section.
Is there a better way to do what I am trying to do. I don;t want to use two separate grids I think it should be doable in one grid.
Any help is appreciated.
Parents
No Data
Reply
  • 469350
    I don't beleive this is possible with scroll regions. As you wrote, the RowScrollRegions will both show the same set of rows.
    My advice would be to use two grids. You could separate your data into two separate tables and put some rows in one grid and others in the other grid.
    Another option would be to bind both grids to the same DataSource and simply use the InitializeRow event to hide the rows that you don't want the user to see in each grid.
Children
