Can anyone point me to an example of how to bind an UltraListView object to an IList object?
I am replacing a ListBox object with an UltraListView.
The original code was just assigning the IList to the property ListBox.DataSource:
availableListBox.DataSource = availableIList;
UltraListView does not have a DataSource property, so I tried:
availableUltraList.DataBindings.Add("Items", availableIList, "Text");
I am new to data binding and my attempt above is failing at runtime with an ArgumentExcpetion because "Items" is read only.
Part of the problem is that I do not understand what I should put for the 1st or 3rd parameter. I have not found any clear documentation.
Thanks in advance,
Larry
Link is not working.. I have to add a List of values to UltraListView. Pls help me
Thanks for the reply. I submitted the request.
I was surprised that it does not support data binding since your website describes UltraListView as a replacement for WinForm's ListBox, which does support data binding.
Can I expect a response to my request, whether yea or nay? Or should I just keep checking every release to see if it's ever implemented?
Because it doesn't support data binding. If you like you can visit http://devcenter.infragistics.com/Protected/RequestFeature.aspx and submit a request for the feature.
I also found that trying to add a binding on the ListBox as shown below also throws the same exception.
availableListBox.DataBindings.Add("Items", availableIList, "Text");
I guess that makes sense since for both classes the DataBindings property is only a getter. But that does not get me any closer to solving the problem.
Why doesn't UltraListView have a DataSource property?
