I didn't see this issue posted yet but when I installed 11.2 Ultimate, it created multiple instances of each control w/in the Visual Studio 2011 Toolboxes. I can't tell if it is duplicating them each time I open Visual Studio 2011 or not but here is a video of my toolbox for the 11.2 4x Controls & Reporting. Please let me know if you want me to try anything or want any other details. Oh, I have also removed the Toolboxes and re-installed w/ the same results. It also does the same for the 11.2 2x Controls.
Hello ,
Thank you for your feedback.
As far as I understand you were able to solve your issue.
Please do not hesitate to contact with us if you have any further questions on this matter.
Thanks Hristo & Alexander. I will give that a shot.
On a different workstation, I installed 11.2 w/o the WP7 controls and it worked flawlessly. I have also uninstalled/re-installed w/o the WP7 and it appeared to resolve the issue. I was planning on working on some WP7 test projects so I will give the hotfix a test once I install the WP7 controls again.
-Ian
I have created a support ticket for you with id CAS-78100-JRLH5L.
Hi Ian,
In general you can have only x64 or x86 reg key depending on the OS installed.
Our WP7 product has a known issue that breaks toolbox for most of our products...
You can contact Developer Support and I can send you a hot-fix for this instead.
Alex
Alex-
I installed the entire 11.2 Ultimate Package so yes to the WP7 question.
Do I remove that entire registry key structure for the x64 & x86? Also, I don't have any .tbd files at that specified location.
This issue pretty much happens for all NA products (WPF, Silverlight, Reporting, Windows Forms, ASP).
Thoughts? I will be testing this on another workstation to see if the same issue arises.
