Is it possible to create following image with your GanttView?
I am developing aviation software. I have records combined with each others. In the picture you can see the different type of the duties. I need layers some of them in the front and some others on the backwards.
Actually there is three records on the chart which are blue ones. I am calculating rest of others. There is turquoise layer you can see on the first record, thin blue line layers connects the records and khaki line layer on the end of the records.
I want to ask before to try this chart if it is possible to draw as I wrote.
Murat
Hello Murat,
Maybe you could achieve something similar to your screenshot if you are using GanttView with relation between the Tasks. Please take a look at the screenshot and attached sample for more details. Please let me know if you have any questions
Have you been able to resolve your issue ? Did you have a time to take a look at the attached sample ? Let me know if you have any questions.
I just try but no success.
I need multiple tasks in one line. But in your solution each task has own line. I am trying to find a way to use my chart in the picture. If I success in two weeks I will buy this products. I've deadline sorry.
Hi
I have implemented your demo/example which is great but the problem am having is that if the parent task is scrolled out of focus then all the sub tasks dissapear as they have nothing to base themselves on.
How could i loo to keep sub tasks on the timeline even when the arent task is moved - i have looked at the TimelineVisibleDateTimeRangeChanged event but wouldnt know what to use to keep it going?
Any help is appreaciated
This one is OK for me.
I am inspecting the scaffold. I will try to implement my graph.
Thanks for the demo.
Our UltraGantView control support multiple tasks, and we represent our subtasks in separate lines (in the grid and chart area).
Maybe one possible way to achieve desired behavior, could be if you are using Creattion Filter. I made small sample with this approach. Please take a look at the attached sample for more details and let me know if you have any questions.
