we have a strange experience on one particular test system. When the tester tries to resize the columns with the mouse he can only shrink the columns. The columns won't grow. But this behaviour occurs only on this one system and can't be reproduced on other systems.
The WinGanttView is Version 11.1.20111.2061. It's hosted with a WindowsFormsHost inside a WPF UserControl which is inside a XamDockManager. The test system is running Win7.
On other test systems (XP, Vista and Win7) everything works fine, but how can we ensure that it won't occure at a customer's system?
Sincerely,
Bastian
Hello Bastian,
Thanks for provided information. I`ll be gald to research your sample, if you are able to reprodice it. Let me know if you have any questions.
Regards
Hello Georgi,
i already thought that this would be the answer. But i was hoping you know some "magic value" which i can try to set.
Our WPF Controls are version 11.1.20111.2173. The whole project uses .Net4, Unity Dependency Injection, Prism V2 and NCAL to host the views in the XamDockManager.
The test system is a Win7 laptop. The only special thing about this laptop is, that it has 3 monitors connected. But the error occurs when the WinGanttView is docked in our MainWindow on the main screen as well as when it's floating on some other screen.
I know it's not much information but as soon as we find more differences to other test systems i will update this thread.
It is very hard for me to say what could cause this behavior. This is the first time when somebody report such kind of issue. I try to reproduce your issue in a small sample, but without success. If you are able to reproduce this issue in a small sample, I`ll be glad to research it. I see that you are using the latest available version of WinGanttView control, but could you please provide us more details about your WPF controls and your Test system.
