Is there a way to control whether a milestone should be visible on the begin of the primary interval or on the end?
In case I have a milestone on 31-12 and my primary interval is one month, the milestone is placed on the begin of december. Instead I would like to see it on the end of the interval.
Maybe the other item in this forum "Show exact timeline length having a Months/Weeks primary interval" will also solve my question, but in the mean time I would like to see some temporary solution...
Thanks for your response. Let me know if you have any further questions
Sorry for the late respons - I only work a few days per week on this project...
I figured it out: My duration of the task was 0 since it is a milestone.When I set the duraction on 0 then it appears on the begin of the month. If it has some duration (even a milisecondsecond) it appears on the end...
HI,
Have you been able to resolve your issue ? Did you have a time to take a look at my suggestion. Let me know if you have any questions
Regards
I try to reproduce your scenario in my test sample, but without success. Could you pleas tell me what is your current version and do you have any installed service release and which one. I`m unsing the latest available version 11.2.20112.2050. If you are using older service relealse, you could download the latest available from our site : Infragistics.com -> MyIG -> My Keys and Downlaods.
Also if you are able to upload small sample that reproduce your issue, I`ll be glad to research it for you. Please take a look at the screenshots below from my tests.
The Constraint is not solving my issue. The problem is not that the date is wrong, but that the optically location in the diagram is wrong:
The two milestones above have as date 31-12, but are shown on the beginning of december. The grouptask just above them end at the 31th also. The deadlines on the grouptask are shown correctly... Is it possible to get the milestones shown at their correct location?
