1935
UltraGrid - DataSource with 3 tables but only 2 of them has relations
Hi
i have 3 tables in the DataSet
2 of them has Relations set but the 3rd table is not a child of any of them and therefore does not have relations to any of the other 2 tables.
what i am aiming for, if it is even possible, is to have 3 bands but only 2 of them are Parent Child and the 3rd is seperate band at the Parent level.
i,e,
Parent  <-table 0
      Child <- table 1
Parent <- table 2 !!!
the Parent of table 2 should always be on the bottom of Parent and Child (tables 0 and 1).
meaning when expanding the parent of table 0 and reveling the Childs (table 1) then the Parent (table 2) will slide down.
i added the 3rd table to the DataSet but the Grid did not respond to it. i dont see the data there and when i check  Grid.DisplayLayout.Bands.Count it shows only 2. meaning it didn't take the 3rd table at all.
is it even possible to achive? do i need to use RowRegionScroll somehow?
Parents
  • 469350
    The WinGrid only supports a single root band - you cannot have multiple root bands. But it seems like you could easily achieve what you want using two grids.
Reply Children
