I am using Infragistics version 11.1.20111.1003. When I drag and drop a control it shows at the bottom of the form as an icon and it doesn't show on the form. Please note that there are other forms that uses the controls with no problem. Those are new forms that I just created. Any ideas what is causing this?
Thanks, Jayson
Sorry, it took so long to reply to your request. I see that you have already tried to check references, remove license contents, clean, rebuild, and reinstall. Have you, however, attempted to contact someone who, for a period of time at least, was your best friend? Unlike you, he is not difficult to find via social media ;-) Hint: middle name.
I am having the same issue. I got a new computer, so had to re-install Infragistics. Then I noticed i could not access the controls on forms, and the controls were at the bottom of the page.
I have tried the steps recommended (check references, remove license contents, clean, rebuild, reinstall) except for manually installing to the GAC, and still have the issue. What can I look at to determine the problem now?
Kristi
Thanks Chris and Mike it worked.
Jayson
Hi Jayson,
As a precaution and as a possible method of remediating this issue, I would recommend the following:
-Ensure that all references within the project are consistent, as only one version of the assemblies may be used at any one time within the same project.
*if there are any references which belong to a version different than the one intended for the project, you will need to delete these references and re-add the appropriate assemblies, manually.
-Ensure that all of the Infragistics assemblies all have CopyLocal and Specific Version set to false.
Once these conditions have been verified:-Delete the contents of the projects licx file.-Close the designer window within Visual Studio.-Clean the project.-Rebuild the project and access the designer.
If these steps fail to correct this issue, and as Mike has suggested, it may be necessary to re-install the version of NetAdvantage that you intend to use; this should re-allocate the required design assembly to the GAC.
It may also be possible to manually re-install the design assembly into the GAC and I have included the following link to MSDN article, which describes this procedure, for reference.
http://msdn.microsoft.com/en-us/library/dkkx7f79.aspx
If you have any further questions regarding this issue or if I may be of any further assistance, please let me know.
Sincerely,Chris KDeveloper Support EngineerInfragistics, Inc.www.infragistics.com/support
vertisit said:Any ideas what is causing this?
Yes, this is what happens when Visual Studio is unable to find the designer associated with a control. Basically, it means that the Infragistics.Win.Design assembly is not in the GAC on your machine, so something did not install properly.
I recommend running the installer again, or maybe uninstall and then re-install NetAdvantage.
If that doesn't help, check your assembly folder and see if you have a version of that dll in the GAC and if so make sure it matches the version of the controls you are using.
