I'm trying to figure out the best way to allow users to update a field in an ultragrid that is a read-only expression field in the underlying datatable. For example lets say I have a datatable with 3 columns. Value1, Value2, and Rate. Value1 and Value2 are decimal values and Rate is a decimal expression equal to Value1 / Value2 in the datatable.
Users are allowed to edit value1, value2, or the rate in the ultragrid. To make this work I am hiding the "Rate" field from the ultragrid and added a new editable column to the ultragrid called "RateEditable". When the "RateEditable" field is updated I make the appropriate calculation to update Value1 or Value2. I was hoping there would be a way that I could make the "Rate" field editable and not have the extra field to make this work. Is this possible?
Thank you for your help in advance.
You can't have a DataFilter that implements OwnerToEditor without also implementing EditorToOwner. This will result in weird behavior like you are getting here.
But anyway, why are you using a DataFilter at all? I don't understand the purpose of this. InitializeRow is a much better and simpler way to populate your unbound column.
Mike, Thank you for your reply. I've run into a problem today and it's related to the solution of the problem explained above. To keep the data in sync I decided to attach a DataFilter to the editable field and when the args direction in the DataFilter is equal to "OwnerToEditor" I return the value of the expression column.
Attached is an example of what I'm doing.
In the project when you click into a "Total Editable" field and then hover over the other Total Editable fields the values start changing unexpectedly. However if you uncomment the code I have in the ultragrid InitializeRow event the Total Editable field displays the expected value.
I believe this is a bug and even though I have a workaround please let me know when this is resolved.
Thanks!
Kurt said:I was hoping there would be a way that I could make the "Rate" field editable and not have the extra field to make this work. Is this possible?
No. Using the unbound column is the best way to go.
