395
Data offset between first and second layer of composite chart
I created a composite chart composed with a column chart and a scatter chart (dotted line).
At first glance, it seems to work ok (see "date offset.jpg"). The problem I have is that there's an offset between the dotted line and the column chart.
For example, if you look at the data that serves to generated the chart (see "chart data.jpg"), the dotted line value at the date "2014-03-02" should be "750" but it is "1350".
The problem I think I have is that the width between two points is not the same as the width of a column, so the offset is created from that. What properties can I adjust to solve this?
As you will see in my code, I had to create an X2 axis to be able to display the dotted line and from what I read, I cannot use the same "string" datatatype on the other axis so I created a "SemaineCount" (WeekCount in English) to use as the X value. Maybe the source of the problem resides there...
Thanks for your help,
Olivier
PS: I added an excel spreadsheet for you to have a reference between what you see on the chart and what the values are supposed to be.
Ultrachart problem.rar
Parents Reply Children
