I am using Infragistic 10.2 and reading excel file using Infragistic.excel
1) To read formula attached to a cell.
Below is the code for reading :
Workbook workbook1 = Workbook.Load("filename.xls");
"filename.xls"
Infragistics.Documents.Excel.Worksheet worksheet = workBook.Worksheets["DifferentFormats"];
string aValue;
for (int i = 0; i < 8; i++){
aValue = worksheet.Rows[i].Cells[1].value;
aValue is reading =T("1299") whereas it has to read 1299 and ignore formula applied to that cell.
Searched on infragistic site and found to use "GetText" property but in version of infragistic to able to find this property.
Due to some restrictions , can't upgrade infragistic version . Can any one suggest any solution for this problem or any sample of code which can read such values.
Please need solution on urgent basis.
Will 2035 service release for v10.2 solve my problem of reading any formula field like T("1299") , VLOOKUP(), SUM(C1,C2) or just VLOOKUP().
Because currently with Netadvantage 10.2 WIN CLR2x , it reading #Name in value property for all above formula.
Need confirmation on this to proceed further for downloading this service. Thanks in advance.
Renuka,
It is very to hear this! I will be waiting for your feedback.
Thanks alot for solving my one issue. I have updated in my application Infragistics3 and it is working fine. Thanks for your quick and useful replies.
I will check regarding service release suggested for formula and update you by tomorrow.
I do not think that you should change anything. Just to be sure - I tested this and it is working fine. What is bothering you exactly, could you paste some code which will not work?
Using Infragistics2.Win.UltraWinGrid.v10.2 and this Infragistics3.Win.UltraWinGrid.ExcelExport.v10.2 will work properly. It will not have version conflict.We have overrided many methods of CGDATAGRID which is of Infragistics2.
