does anybody know how the text of a ‘StateButton’ and of a ‘MaskedEditTool’ can be left aligned in a ribbon?
The sample project is attached.
Thank you very much for any suggestions!
Frank
Dear Mr. Hristo,
The version 2014.1 does solve this issue.
Thank you very much for your help and congratulations to the developer team.
Best regards
Thank you very much for your great help in this case and I am very happy that the Infragistics team is always doing a good job.
I’ve crated support ticket (case) in our issue tracing system for you, in order to be able to investigate this issue further. The id of the ticket is CAS-133966-D4L9X4, so I will update you via the case as soon as I have more information for you.
Both machines run under Windows 7 64 Bit SP1 and both with the Windows 7 basic theme. Machine 1:Screen resolution 2560x1440Text: Size medium 125% Machine 2:Screen resolution 1400x1050Text: Size standard 100% What I have observed with completely different application software is that the setting of text size to medium 125% is the most critical thing.
Thank you very much for your investigation.
regardsFrank
Could you please list several specific environments (operation system, windows themes, fonts and etc. ) on which you are able to reproduce this, in order to be able to verify this on my side and to research for a possible solutions.
I am waiting for your feedback.
