390
Problem with UltraCombo as column headers - can't select items
I am using a creation filter to overlay an UltraCombo for all column headers in a grid.  I am experiencing the same problem as this post: http://ko.infragistics.com/community/forums/p/43867/239732.aspx.  The UltraCombo is appearing in the column header but the drop down does not open and allow me to select items.  I have attached my creation filter code and a screen shot of the grid.
The UltraCombo allows me to set the SelectedRow and/or Text property fine.  However, setting different Appearance properties in the creation filter has no effect (ie, combo.Appearance.ForeColor = Color.Indigo; below).
What am I missing?  Any ideas?  Thanks!
Here is the code:
internal class HeaderComboBoxCreationFilter : IUIElementCreationFilter
        public void AfterCreateChildElements(UIElement parent)
            if (parent is HeaderUIElement)
                EditorWithComboUIElement comboBoxUIElement = null;
                UltraGridComboEditorOwner embeddableEditor = null;
                EditorWithCombo editor = null;
                UltraCombo combo = null;
                combo = new UltraCombo();
                embeddableEditor = new UltraGridComboEditorOwner(combo);
                editor = new EditorWithCombo(embeddableEditor);
                comboBoxUIElement = new EditorWithComboUIElement(parent, embeddableEditor, editor, null, true, true, true, true);
                combo.DataSource = CreateColumnDataTable();
                combo.DisplayMember = "name";
                combo.ValueMember = "value";
                //combo.Text = "Text1";
                combo.SelectedRow = combo.Rows[0];
                combo.Appearance.ForeColor = Color.Indigo; // this does not have an effect
                combo.DropDownStyle = UltraComboStyle.DropDown;
                combo.DropDownButtonDisplayStyle = Infragistics.Win.ButtonDisplayStyle.Always;
                comboBoxUIElement.Rect = parent.Rect;
                parent.ChildElements.Add(comboBoxUIElement);
        private DataTable CreateColumnDataTable()
            DataTable dataTable = new DataTable();
            dataTable.Columns.Add("name", typeof(string));
            dataTable.Columns.Add("value", typeof(string));
            dataTable.Rows.Add(new object[] { "Name1", "Value1" });
            dataTable.Rows.Add(new object[] { "Name2", "Value2" });
            dataTable.AcceptChanges();
            return dataTable;
        public bool BeforeCreateChildElements(UIElement parent)
            return false;
ComboBoxAsColumnHeaders.zip
