I am using UltrGridView to display hierarchical data in different bands (1 parent band and two child sibling bands). and on every row click i am refreshing the dataset binding by the following code
this.ugvProducts.Invoke(new SetDataBinding(SetDataBindingMethod), DataSetFinal);
i am getting this BIG RED Cross Sign on the grid now and then as most of the time application runs correctly but some time it shows CROSS and application needs to be restarted in that case.thats a big problem
1-What causes it?
2-How can i correct it?
A big red X means that an exception occurred during the Paint event of the control.
This could be a bug in the control, or it could be caused by the improper use of threading in an application.
I am facing red cross issue with my tree view.Infragistics version 10.2
I want to know for what reason this problem occurs.
Any possible solution.
Apurwa
Hello ,
Thank you for your feedback.
Since version Infragistics volume 7.2 was expired, I suggest you to download our new Infragistics 14.1, you could download it from the following link:
http://ko.infragistics.com/products/windows-forms/
I’ve update my sample in order to demonstrate some simple usage of updating of underling data source in background thread and I hope that this will helps you.
Thank you for your time and interest,
The solution you have provided is using Infragistics4(14.1) references but my project is using Infragistics2 with version number (7.2.20072.61) and i cannot update it now.Can you please update the source according to my Infragistics2.It will be highly appreciated.
Secondly Child rows in my Project are updating from db in a seperate thread on each click. Can you please implement this in your project because i have to do it in seperate thread if thats possible.
Regards:
Adeel Saleem
I’ve implemented my suggestion in the context of your scenario. Please run my sample and let me know if this is what you are looking for.
I am waiting for your feedback.
