275
Adding Button to column header
I am using NetAdvantage for .NET 2008 Vol. 2 CLR 2.0.
I have several questions regarding adding a button to a UltraWinGrid column header and having it do something useful.
Right now, I have managed to create the buttons by using a CreationFilter on the UltraWinGrid; i.e. I set
ugPatientList.CreationFilter = New AddUpdateButtonsCreationFilter()
in the form's Load event.
The function itself is pretty basic:
Public Function BeforeCreateChildElements(ByVal parent As Infragistics.Win.UIElement) As Boolean Implements Infragistics.Win.IUIElementCreationFilter.BeforeCreateChildElements
Dim value As Boolean = False
      If TypeOf parent Is HeaderUIElement Then
          Dim btnElement As ButtonUIElement
'parent.ChildElements.Clear()
btnElement = New ButtonUIElement(parent)
          btnElement.Rect = New Rectangle(parent.Rect.X + 2, parent.Rect.Y, _
                                          CInt(parent.Rect.Width * 0.55), CInt(parent.Rect.Height * .75))
btnElement.Text = "Update"
'Dim btnToolTip As Windows.Forms.Control = TryCast(parent.ToolTipItem, Windows.Forms.Control)
'btnElement.ToolTipItem = Infragistics.Win.ToolTip(btnToolTip)
parent.ChildElements.Add(btnElement)
value = True
     End If
     Return value
End Function
The buttons show up on every column header, but now the captions don't appear!  So I have four questions:
  1. What's the best way to have both the button and caption show up in the header?
  2. How can I turn the Hidden property of a button to True in a difference procedure (i.e. how do I reference the button object outside of this function)?
  3. How do I handle a button's Click-type event?
  4. How do I add a tooltip to the button?
