Hi,I am using Infragistics UltraWinToolbars.v11.2.20112.2112. In the app there is nothing on the form except a toolbar. I am using an isl template file office2010.isl. from Infragistics AppStylist.In Windows 7 Basic theme, if I minimize the app and then bring it back by clicking the app icon on windows toolbar, the toolbar does not get painted. It shows gray rectangle and there is NO way to bring back the toolbar except to kill the app.Issue does not happen in any of the other windows 7 theme.Is this a known issue?
I am just checking about the progress of this issue. Let me know If you need my further assistance on this matter?
If you are able to provide us with a small sample and steps to reproduce which will allows us to consistently reproduce the issue, I will be glad to investigate this further for you.
I am waiting for your feedback.
Perhaps I was too hasty. The problem went away for a bit but now it's back. I'll update if I find anything more definitive.
I had the same issue when adding a ribbon to and upgrading an existing project. What appeared to be the issue for me was using having a menu in the toolbarmanager named Application Menu. I think that was conflicting with the Application Menu settings in the ribbon somewhere along the way. When I removed that menu, the problem went away. We are using 14.2.20142.2010.
Hello ,
It seems that I was missed (or actually add additional step) when reproducing this on my side. I was able to repro the issue on Windows 7 with 11.2 and also I’ve tested it with the latest version of Infragistics 14.2 and it is not reproducible there. So my suggestion is to upgrade to latest Infragistics 14.2, you could download free trail evaluation version from the following link:
http://ko.infragistics.com/products/ultimate/download
