245
Failed to create component.... new installation VB2010
I'm using VB 2010 - Winforms and just did an installation of the Trial version of Infragistics controls.  I want to test if the controls will help speed up my development.
I had problems with installation of the Indigo Studio because my Silverlight was not up-to-date.  After the installation completed, I attempted to add a control to a copy of one of my Windows Forms projects (after I changed the target framework to version 4), and received the error Failed to create component.
I found some references to older (2009) articles about setting the Specific Version option to False on all Infragistics References and to clean out the licenses.licx file.  I was able to set the references to false but could not find a licenses.licx file associated with my project.  Still errors.
So I reset my Windows 7 Pro SP1 machine to a restore point from before the installation.  I upgraded my Explorer and Silverlight before installing again.  Reinstalled and had the same problem.
I created a new project with one form and made sure it was referencing .Net 4 (not client), added a control and again received an error.  Of the dozen or so controls I have tried, only the UltraProgressBar  and UltraScrollBar will insert on the form.  I can see the References being added in the Solution Explorer but the error still shows up.
One example of the message is below.
If anyone has any ideas what I can try to test the controls, I would appreciate it.  TIA, rasinc.
