2085
Infragistics 15.2 XamDataChart Exception
We are testing an upgrade from Infragistics V15.1..20151.1000 to V15.2.20152.1000 and see an exception 15.2 that we do not see in 15.1 and have made zero code changes (just imported the 15.2 DLLs).  Two of the stack traces are shown below.  In our test environment, we get this error when a XamDataChartis initially rendered and then do not see this error again even when changing data displayed on the XamDataChart, unless we close and re-open the screen containing the XamDataChart (a new XamDataChart is created in this event, so it seems something changed with the way a XamDataChart is created/displayed for the first time?).  In some spots of our code, the VS studio stops on a XamDataChart.Flush() call, but I don't see a reference to any of our code in the stack traces.  Can some one determine what the issue is based on the stack trace, or do I need to try and provide an example application?
System.ArgumentOutOfRangeException: Ticks must be between DateTime.MinValue.Ticks and DateTime.MaxValue.Ticks.
Parameter name: ticks
   at System.DateTime..ctor(Int64 ticks)
   at Infragistics.Controls.Charts.CategoryDateTimeXAxis.RenderAxisOverride(Boolean animate)
   at Infragistics.Controls.Charts.Axis.DoRenderAxis(Boolean animate)
   at Infragistics.Controls.Charts.ContentInfo.DoRefresh()
   at Infragistics.Controls.Charts.ChartContentManager.EnsureAxesRendered(Size plotSize)
   at Infragistics.Controls.Charts.ChartAreaPanel.MeasureOverride(Size availableSize)
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV, Boolean& hasDesiredSizeUChanged)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.Controls.TabItem.OnPreviewGotKeyboardFocus(KeyboardFocusChangedEventArgs e)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
   at System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
   at System.Windows.Input.KeyboardDevice.Focus(IInputElement element)
   at System.Windows.UIElement.Focus()
   at System.Windows.Controls.TabItem.SetFocus()
   at System.Windows.Controls.TabItem.OnMouseLeftButtonDown(MouseButtonEventArgs e)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
