1385
Trying to remove selected record results in NullReferenceException
I am trying to use a XamDataGrid to display a set of records, and users have the ability to select rows and delete them using a button.  When I hit the delete button, the command removes the item from the collection and results in a NullReferenceException.  The stack trace is below.  We are using v15.2.2038 (the new service release).  I am attaching a sample project (VS2015).  You will notice the exception only happens if the row to be removed (in this case the first one) is selected.
This is a bad time, as I am nearing a ship date and we were waiting for the SR release to fix another problem, thus making it difficult to go back to a previous release.  A workaround would be great!
at Infragistics.Windows.DataPresenter.RecordManager.RemoveRecordHelper(Int32 index)
at Infragistics.Windows.DataPresenter.RecordManager.OnSourceCollectionAddOrRemove(NotifyCollectionChangedEventArgs e)
at Infragistics.Windows.DataPresenter.RecordManager.OnSourceCollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
at Infragistics.Windows.DataPresenter.RecordManager.ProcessChangeNotification(Object sender, Object eventArgs)
at Infragistics.Windows.DataPresenter.RecordManager.OnChangeNotification(Object sender, Object eventArgs, Boolean isReset, Boolean isCellChangeNotification)
at Infragistics.Windows.DataPresenter.RecordManager.System.Windows.IWeakEventListener.ReceiveWeakEvent(Type managerType, Object sender, EventArgs e)
at System.Windows.WeakEventManager.ListenerList.DeliverEvent(Listener& listener, Object sender, EventArgs args, Type managerType)
at System.Windows.WeakEventManager.ListenerList`1.DeliverEvent(Object sender, EventArgs e, Type managerType)
at System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args)
at System.Collections.Specialized.CollectionChangedEventManager.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args)
at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
at System.Collections.ObjectModel.ObservableCollection`1.RemoveItem(Int32 index)
at System.Collections.ObjectModel.Collection`1.RemoveAt(Int32 index)
at DeleteRespIssue.ViewModel.Remove(Object parameter) in D:\Development\ZScratch Projects\DeleteRespIssue\DeleteRespIssue\MainWindow.xaml.cs:line 97
at DeleteRespIssue.BasicCommand.Execute(Object parameter) in D:\Development\ZScratch Projects\DeleteRespIssue\DeleteRespIssue\MainWindow.xaml.cs:line 168
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at System.Windows.Application.Run()
at DeleteRespIssue.App.Main() in D:\Development\ZScratch Projects\DeleteRespIssue\DeleteRespIssue\obj\Debug\App.g.cs:line 0
at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
DeleteRespIssue.zip
Parents
  • 16495
    Thank you for your post.
    I have logged this behavior with our developers in our tracking system, with an issue ID of 211278.  I have also created a support ticket on your behalf with number CAS-167850-Z6T0G5 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Reply Children
