I have been investigating into this issue, and I have created a sample project using version 16.2.20162.2045 and very much based on the sample code that you have provided. However, I am currently unable to reproduce this NullReferenceException that you are seeing on my end after hovering over the columns in the XamDataChart.
I have attached the sample project I have used to test this issue. Please test this project on your machine, as its behavior may help to indicate the nature of this problem. If the project does not work correctly, this indicates either a problem possibly specific to your environment.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one. I have noticed that there are a couple of things that I am missing related to the XamPivotGrid related to styles and event handlers, but I am unsure what is happening in your application regarding those at the moment. It may also be helpful if you could provide a stack trace of the NullReferenceException you are seeing.
Sincerely,AndrewAssociate Developer
We have extracted and cut down a piece of our application for use as test bed for reproducing the error conditions.
Do you have an email address that we can email the zipped solution to as it has sensitive IP in it that we do not want to post on an open forum ?
Best Regards
This support incident is 1 of 3 WPF related current support incidents.
I have uploaded a sample application that covers this support incident (and the other 2 incidents) to the Support Activity section under CASE NUMBER / CAS-179935-B3H2Z5 .
Hello PV87992,
Thank you for your update.
As you have mentioned that this concerns a sensitive IP on your end, and would rather not discuss this issue on the forums, I have created a private support case for you on this matter so that we can continue our discussion there. This support case has an ID of CAS-180079-R2X5Q1 and you can access it at https://ko.infragistics.com/my-account/support-activity.
