How can I hide the close button and enable the Autohide button in XamDocManager panes.
Below is my code
<idm:XamDockManager x:Name="Dock"> <idm:DocumentContentHost> <idx:ContentPaneFactory.PaneFactory> <idx:ContentPaneFactory RemoveItemOnClose="False" ItemsSource="{Binding ItemsSource,RelativeSource={RelativeSource TemplatedParent},Converter={x:Static rtc:DummyConverter.Default},ConverterParameter={}ContentPaneFactory ItemsSource}" HeaderPath="Header" ContentPath="." > </idx:ContentPaneFactory> </idx:ContentPaneFactory.PaneFactory> </idm:DocumentContentHost> </idm:XamDockManager>
Hello Richa,
ContentPaneFactory is not a part of the XamDockManager control implementation. The best way for us to assist you is if you provide a small isolated sample that we can run and use for debugging locally.
Let me know if you have any questions with this matter.
Thanks for the sample code, but your sample code does not include how I can hide/disable close button while using ContentPaneFactory because in my code I am using ContentPaneFactory and I cannot find out any AllowClose property within it.
You can use the ContentPane AllowClose property to configure the visibility of the Close button. I don’t think Auto Hide option is possible for the panes placed in DocumentContentHost. It is an option for the panes placed in SplitPane for example.
I’ve attached a sample project for your reference.
Let me know if I may be of further assistance.
Svetla Boykova
