since we want to have dynamics count of values on data chart, we decided to use dynamics/ExpandoObject which works pretty nice in the way that I can use virutal properties which would be fine.
But this doens't work with XamDataChart since it's needed to handle the objects as dynamic and not as object.
Does it support that?
I've found this thread but it's six years old, so, may be something changed
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-wpf/54727/xamdatagrid-binding
Best regards
Hello Timon,
After investigating this and doing some research, expand objects in XamDataChart has been determined to be a product idea. You can suggest new product ideas for future versions by emailing ideas@infragistics.com.
Submitting your idea will send it directly to our product management team so that it can be imported into our new ideas community once live: http://ideas.infragistics.com.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. You can also link back to this thread for additional details.Thank you in advance to submitting your product idea.
Include a link to this thread in your idea so product management will be able to look back at this case.
Sincerely,Mike P.Software DeveloperInfragistics, Inc.www.infragistics.com
