1255
XamTreemap label fontsize
How do I set the fontsize for a treemap label so it stays.
I currently bind the fontsize using the XamTreeMap property FontSize.  Then I bind the label to a a string Label property using a NodeBinder.  Everything works fine and the user can change the label fontsize with no problems.
However, if I then change the label in the node using an OnPropertyChanged the font size of the label changes to some default and the user can no longer change the label fontsize.
How do I set the fontsize for a treemap label in a nodebinder with TextPath="Label" after the label name is updated using an OnPropertyChange.
