455
removing a document from xamdockmanager
I seem to have an issue with the xamdockmanager. I can add documents with no problem with the .adddocument command, but the problem lies with going in and removing those documents.
I have a xamdatagrid that I use and, for example, if I have multiple rows I want to select I highlight them and click the "load case" button and for each row selected, it will load the primary key, find the document, and add it to the xamdockmanager. I then have that equalled to a contentpane. I also have the xamdockmanager.content = documentcontenthost. But I have not been able to find much infomation on that control. Is there a way to access the documents in the documentcontenthost or the xamdockmanager based on the header.
Thanks in advance,
 Joel
