45
Strange behaviour when IsListContinuous set to true.
I am trying to implement a continuous list in the XamCarouselListBox but have found some very strange behaviour in the scrolling actions.  I started with the following sample:
http://blogs.infragistics.com/blogs/ctaylor/archive/2008/06/17/carousel-listbox-selection.aspx
When the IsListContinues property is set to True, clicking on the right-hand items works until you select the first or second item in the databound list... then the carousel jumps that item back to beginning and scrolls the wrong direction.  I have tried numerous ways to fix it but nothing great.  I have one solution that works for carousels that have a definite "left & right side" or "top & bottom" (track which side the mouse is clicked on, then call the NavigateToNext/PreviousItem the required number of times) but of course it would break with custom paths that move around a lot and it also doesn't scroll very nicely (if you call it twice, you only see the second scroll).
 Any thoughts?  I think the problem might be with the SetVerticalOffset method call, but I can't find anything helpful on the net about alternatives.
 I think there should be a better way since the navigator "next page" and "next item" button presses scroll the list very nicely.. they just don't change the selected item when they scroll... and what I want is the user to be able to "select" an item in view and have it scroll to the center as well.
