It appears that when I change ContentPane.CloseAction to RemovePane and close a pane, the next active pane is not the pane that was last active. However, the pane activation order is as expected (last active pane) when the CloseAction is HidePane.
This behavior is strange and my users are complaining. Is there any way to get the expected activation order when CloseAction is RemovePane?
Andrew Michell
This doesn't sound like the correct behavior. Do you have a sample that reproduces the issue that I could see? I would recommend contacting the support group and providing a sample that demonstrates the issue.
I've submitted a sample to support. The case number is CAS-18559-J9VZWI.
simonped7, I have reproduced this issue and I will follow up with you in a private support case.
For others following this issue, please note that it has been logged as Development Issue 74484.
Yes it is the latest, 2010.3. To duplicate,
The desired behavior can be seen if you do those steps when the close action is set to Hide Pane on all the ContentPanes.
Hello simonped7,
The customer who opened this thread reported to us that the Service Release did resolve the issue in NetAdvantage v8.2. What version of NetAdvantage are you encountering this issue with? Do you have the latest Service Release installed?
Has this been resolved? I'm still finding the issue
