360
Sort column With Image
I took a look at the samples and pretty much copied the xaml to place an image in one of the cells.  The images i am using actually mean something to my users, and i need some way to sort those images.  For example if i have an image that means Error, another image that means Caution, and i want all of the "Error" to show at the top and then the Cautions below that ect.  Can anyone advise of a way where i can do that.  I have a column in my object but that is hidden that is basically and Enumeration but it is not even defined in the field layout.  It would be nice if i could also keep the default sorting of the other columns, meaing that i don't change the behaviour completely.
Parents
No Data
Reply
  • 9836
    Verified Answer
    One possible implementation is to handle the Sorted event of the grid and then sort the image column based on your enumeration column values. You would need to add the enumeration column to the fieldlayout so you can point to this field when you create the FieldDescription :
    private void xamDataGrid1_Sorted(object sender, Infragistics.Windows.DataPresenter.Events.SortedEventArgs e)
           Field current = e.Field;
           if (current.Name == "ImageColumn")
                   FieldSortDescription enumSort = new FieldSortDescription();
                   enumSort.Direction = System.ComponentModel.ListSortDirection.Ascending;
                   enumSort.FieldName = "EnumerationColumn";
                  this.xamDataGrid1.FieldLayouts[0].SortedFields.Clear();
                  this.xamDataGrid1.FieldLayouts[0].SortedFields.Add(enumSort);
    I hope this helps.
    Vlad
Children
