2815
Binding to CellValuePresenter.IsSelected
When a record is selected within the xamDataGrid, I want a property named IsSelected on the underlying data item to be set to true.   My xamDataGrid has the following resources defined:
      <igDP:XamDataGrid.Resources>
                    <Style TargetType="{x:Type igDP:RecordPresenter}" >
                        <Setter Property="IsSelected" Value="{Binding Path=(igDP:DataRecord.DataItem).IsSelected}"/>
                    </Style>
                    <Style TargetType="{x:Type igDP:CellValuePresenter}" >
                        <Setter Property="HorizontalContentAlignment" Value="Left"/>
                        <Setter Property="BorderBrush" Value="{StaticResource DataGridCellOuterBorder}" />
                        <Setter Property="BorderThickness" Value="1,0,0, 0" />
                        <Setter Property="Padding" Value="5,0,0, 0" />
                        <Setter Property="FontWeight" Value="Bold" />
                        <Style.Triggers>
                            <DataTrigger Binding="{Binding Path=(igDP:DataRecord.DataItem).Status}" Value="Acknowledged">
                                <Setter Property="FontWeight" Value="Normal" />
                            </DataTrigger>
                        </Style.Triggers>
                    </Style>
                </igDP:XamDataGrid.Resources>
When I select a record, my data item's IsSelected property is not being set to true.
What am I missing?
TIA,
Klaus
Parents
No Data
Reply
  • 20
    Hi, Did you tried
    <Style TargetType="{x:Type igDP:DataRecordCellArea}" BasedOn="{StaticResource DataRecordCellAreaStyle
    <!-- To bind selection property to ViewModel Item !!!! -->
    <Setter Property="IsSelected" Value="{Binding DataItem.IsSelected, Mode
    =TwoWay}"/>
    </Style
Children
