2549
How to remove a row from XamDataPresenter
Good morning,
I just started with the Infragistics WPF suite. While I use the Infragistics Windows Forms suite for quite a while now I stepped into a problem.
Here's the case:
I have a BindingList containing objects, nothing special.
That BindingList is bound to a xamDataPresenter using an ObjectDataProvider in XAML.
So far so good, records get displayed as expected.
Not there is a "remove" button that should remove a selected row.
How can I do this in code?
I already tried:
DataPresenterCommands
.DeleteSelectedDataRecords.Execute(null, dpOverview);
dpOverview.UpdateLayout();
...which does nothing, I casted the DataSource to a BindingList of correct type and removed the record there, not visible and even if I delete the item from the database I am not able to remove the corresponding row.
How can this be done in code? Any hints are kindly appreciated.
best regards
Andy
