1. Switching to 2010.3, suddenly there is now a red border around the xammaskededitor when the input changes (even if it is valid). How do I get rid of this? This is really bad - I need a way to prevent this.
2. ValidationConstraints doesn't work - it prevents the spin buttons or any keyboard input, even if the value is between the specifid min and max.
3. After all this, I wanted to validate the input with event handlers, but apparently there are no events raised when the increment or decrement buttons are pressed, nor is there a 'valuechanging' -only a 'valuechanged' -- I don't want to check if the data is valid after its been changed, I want to validate before it's about to change so I can cancel it.
Thanks for your help, in advance.
Thank you for your feedback. I am glad your application is operational.
Sam
My apologies for taking so long to get back to you. This turns out to have been a change in the behavior of a converter when we switched from .net 3.5 to 4.0, and not related to the infragistics controls.
Can you recreate the red border issue on the attached sample so I can review it?
What exactly doesn't work on validation constraint? Instead of firing an event and cancelling it, there is a property you can use "InvalidValueBehavior" to reset the value.
If you recreate the issue, please tell me about your environment, Operating System, etc., so I can test in the same environment.
Thank you,
