1410
Setting the style for UnboundField based on it's value?
Hi.
Using XamDataGrid 2011.1
I've googled all the sites and checked Feature Browser for solution, but didn't find.
Given:
XamDataGrid with some unbound fields. Some of the fields are set for "indexer's" properties. Thus, unboundField's BindingPath property is set as:
["value1"]
["value2"]
["value3"]
.. and so on (with [ ] brackets!)
Correspoding Model object has indexer property like:
public string this[string attributeName] {
            get {
And all works great, I can see those indexer values inside cells.
Now, I want to have custom CellValuePresenter style, such as: if value is equal to "x", - let the text be blue, if value is equal to "y" - let the text be green,  if value is equal to "True" - let it be checkbox displayed. What is displayed doesn't matter. What does matter is that I cannot dig into the "current" indexer property that is displayed. The Record.DataItem of the CellValuePresenter is always the main object, thus I don;'t know which value I'm displaying now.
 <Style x:Key="TimeSeriesCell" TargetType="{x:Type igDP:CellValuePresenter}">
                <Setter Property="ForegroundStyle">
                    <Setter.Value>
                        <Style>
                            <Style.Triggers>
                                <DataTrigger Binding="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type igDP:DataRecordCellArea}}, Path=???????" Value="True">
                                    <Setter Property="TextBlock.Foreground" Value="Blue"/>
                                </DataTrigger>
                            </Style.Triggers>
                        </Style>
                    </Setter.Value>
                </Setter>
            </Style>
What is under Path always referes to main object that contain the indexer property.
How to deal with it?
Parents
  • 3255
    Hello Lukas,
    You may set the Relative Source mode to self  and Path to Value in this case.  I would also suggest you to use a different style for each field i.e., create mulitple cellValuePresenter styles, one for each field so that you would know what field the style was being used for.
Reply Children
