Hi
We recently migrated to office 2010 & when I try to import the .xlsx file getting following exception
Index was out of range. It must be non-negative and less than the size of the collection.Parameter name: indexActual value was 0.
.xls file is fine. We are using v10.1 version of Infragisctics.
Pls let me kow how to solve this issue
thanks
-Kiran
Hello Kiran,
For this issue you can find case CAS-92412-R3QKZM at the support activity page: https://ko.infragistics.com/Membership/MySupport.aspx.
Attached one more file
We are facing lot of issues with the patch version you guys provided. We found these in Production & had to revert back (Took lot of heat from users). Pls provide me only excel fix. We don't want anyother changes.
I ahve attched the issues file. since I can attach only 200 MB. I wil raise one more post & attach another file.
Thanks for the reply. I figured it out the same.
I have been looking into the modified sample and I can say that this behavior is expected and is by design. I can suggest you loop through the FilterRecords collection items and check whether they have conditions. This way you will be able to know how many active filter are applied to the XamDataGrid. You can do something like this:
int count = 0; foreach (var item in xamDataGrid1.FieldLayouts[0].RecordFilters) { if (item.Conditions.Count != 0) { count++; } } MessageBox.Show(count.ToString());
Hope this helps you.
