I am trying write a template to Legend control. I have version 10.3, .net 4, xamDataChart, with a few line series.
My Legend is Horizontal and I want this to wrap when i have many items(series). Something thing like tab control showing multiple lines. Is this possible? I have to have my Legend at the Top.
I have custom Legend template and Legendtemplateitem, but it's not working. I just comented the ScrowViewer and replace this for a WrapPanel.
Any Help is welcome.
<ControlTemplate x:Key="xamDataChartLegendTemplate" TargetType ="Charts:Legend">
<Grid>
<Border BorderThickness="{TemplateBinding BorderThickness}" BorderBrush="{TemplateBinding BorderBrush}" CornerRadius="4" Background="{TemplateBinding Background}">
<Grid Margin="{TemplateBinding Padding }">
<Grid.RowDefinitions>
<RowDefinition Height="auto"/>
<RowDefinition Height="*"/>
</Grid.RowDefinitions>
<ContentPresenter Grid.Row="0" Content="{TemplateBinding Content}" />
<!--<ScrollViewer Grid.Row="1" HorizontalScrollBarVisibility="auto" VerticalScrollBarVisibility="auto" BorderThickness="0" Background="Transparent">-->
<WrapPanel Orientation="Horizontal" Grid.Row="1">
<ContentPresenter Grid.Row="1" x:Name="ContentPresenter" />
</WrapPanel>
<!--</ScrollViewer>-->
</Grid >
</Border>
<Border IsHitTestVisible="False" BorderThickness="{TemplateBinding BorderThickness}" BorderBrush="Transparent" CornerRadius="4" Background="{StaticResource GenericOverlay}" />
</Grid>
</ControlTemplate>
DataTemplate x:Key="xamDataChartCustomLegendItemTemplate">
.Visibility}">
.LegendItemBadgeTemplate}" />
Thank you for your post. I have been looking into it, but I wasn’t able to reproduce your behavior, so if this is still an issue for you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you.
Hi Stefan,
I have attached a sample project showing that.
I want the legend to show all the series data.
Any help is welcome.
Jorge Arteiro
I am new Infragistics and I am trying to simply plot a 2 line series on the XamDataChart and show the legend for the two series through C# programming. Unfortunately the legend doesn't come up at all. Can I know what the reason might be. I am exactly using the same code as the given in the online documentation. Below is the code I am using. I would really appreciate if you could help me with this.
Thanks.
SimpleDataCollection data = new SimpleDataCollection(); XamDataChart DataChart = new XamDataChart(); Legend leg = new Legend { Content = "Legend", Margin = new Thickness(20), VerticalAlignment = VerticalAlignment.Top, HorizontalAlignment = HorizontalAlignment.Right }; DataChart.Margin = new Thickness(5); DataChart.DataContext = data;
// XAxis CategoryXAxis xmXAxis = new CategoryXAxis(); xmXAxis.Interval = 50; xmXAxis.ItemsSource = data; xmXAxis.Label = "{Label}";
// YAxis NumericYAxis xmYAxis = new NumericYAxis(); DataChart.Axes.Add(xmXAxis); DataChart.Axes.Add(xmYAxis);
// Series LineSeries series = new LineSeries(); series.ValueMemberPath = "Value"; series.XAxis = xmXAxis; series.YAxis = xmYAxis; series.ItemsSource = data; series.Title = "Navya"; series.Legend = leg;
LineSeries series1 = new LineSeries(); series1.ValueMemberPath = "Value"; series1.XAxis = xmXAxis; series1.YAxis = xmYAxis; series1.ItemsSource = data; series1.Title = "nnn"; series1.Legend = leg; DataChart.Legend = leg; DataChart.Legend.Visibility = Visibility.Visible; DataChart.Series.Add(series); this.LayoutRoot.Children.Add(DataChart);
I have been looking into your post and I can say that you have to add the Legend object to the Visual tree as well as the XamDataChart, so I can suggest you add the following code at the end of the one you have shared:
this.LayoutRoot.Children.Add(leg);
Hope this helps you.
is this product idea implemented ? i am running into the same problem , need to wrap items instead of one item per line in vertical orientation.
any response.
I need this also, I need to be able to change the item panel from the default stackpanel to something else. Any word on when this will be made available? This is a pretty normal feature.
This feature is not yet implemented, but you can use a workaround. You can inherit the LegendBase class and create your own legend. I attached a sample project showing how to do so.
