Hi Infragistics-Team,
I've got a problem with the datamanager when I'm using the ExchangeScheduleDataConnector. The connection works great and the schedule shows all my appointments etc. from my exchange account. But when I use the method "DataManager.GetActivities" I always get a NullReferenceException.
Using the "normal" ListScheduleDataConnector, the method works great and returns me a proper ActivityQueryResult from which I can get all activities in a ReadOnlyNotifyCollection using the ".Activities" - property.
To help you understand my problem I've put a test-solution in the attachment.
PS:
My intention is to get all appointments etc. from exchange which are displayed on my scheduler so I can store and use them offline too (e.g. with the ListScheduleDataConnector). Because when the connection is lost all displayed appointments disapear.
So if you can help me with my problem I've described above or if you have a better solution for my intention, please let me know!
Many thanks in advance
Sebastian
HI,
This issue has been resolved by the latest service release.
Please let me know if you need further assistance.
Sincerely, Matt Developer Support Engineer
This issue has not been resolved yet, but it will likely be resolved for the next SR.
Is there a solution to this problem yet? I am currently evaluating the exchangedataconnector for possible use in our applications but we encounter the same problem.
What I am trying to do is simply add, edit and delete activities in code.
Thanks in advance
Thank you very much for your fast answer and support. I hope a solution for this problem can be found. I'm looking forward to hear from you. Best wishes Sebastian
This may be a bug. I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
