Is it possible to change the ContentPane hiding speed (autohide mode) in a xamDockManager ? My customer thinks it's hiding too fast...
I tried to play with the AnimationSpeed enum on the xamDockManager, but it didn't change anything on the behaviour of the hiding speed.
Many thanks in advance,
Thomas
Thans for your reply.
No, the xamDockManager is currently set up to process the flyout/flyin animation in about 1/4 second. If you want to see a property exposed to control the animation speed you should submit a suggeston here with as much details about the requirement as possible. Again, there are also times that the animation is skipped such as when an HwndHost is hosted in the pane.
Andrew Smith"] That is the Windows Forms UltraDockManager control. This forum is about the WPF XamDockManager. If the question is about the UltraDockManager then it would be best to post the question in the UltraDockManager forum here.
You're right. My application was using both DockManager : The "Winform one" and the "Xam one". The Winform one has been kept only for safety reasons and is not in use anymore (it was hidden in the code behind) : that's why no matter which property I changed, there was no difference.
My question is still concerning the xamDockManager : is there a way to slow the hiding speed of a pane by changing the UnpinnedTabFlyout property ?
Hi Andrew, and thanks for you reply.
I was referring to this property of the UltraDockManager : http://help.infragistics.com/Help/NetAdvantage/WinForms/2012.1/CLR2.0/html/Infragistics2.Win.UltraWinDock.v12.1~Infragistics.Win.UltraWinDock.UltraDockManager~AnimationSpeed.html
I tried each value, from Plus5 to Minus5, but didn't notice any difference in the behaviour when hiding a ContentPane.
