1690
Minimized xamDialogWindow
We have WPF application which uses xamDialogWindow as a base class for MDI-like interface. For now all minimized dialog windows are located in upper left corner of the main container window and look like empty box 400 x 400 pixels, without header. I tried to explicitly set MinimizedHeight and MinimizedWidth in XAML and code behind - no result. I tried to create a panel in parent window XAML and specify it's name in MinimizedPanel - no result. I tried to explicitly create Panel and and set MinimizedPanel in code behind - in this case minimized panel just disappear.
Is it possible to create MDI-like minimized windows using xamDialogWindow ?
Ed
