I could not find a forum for the Expander control, so if this is in the wrong place I can re-post or maybe this post can be moved.
I am not sure if the Expander is meant to be used alone but (I see it used with a PiviotChart in the samples). I would like to use it to hold a series of input controls. The idea is the user fills out the form in the Expander and click OK and the results are shown next to the Expander, possibly a DataGrid. So its simple, a two column layout with the Expander containing input controls (aka a form) in the first column and a DataGrid in the second column showing results.
My question is ... is there a way to hide the header at the top of the Expander? Even when I do not have anything set for the Header it still shows an empty Header at the top. I would very much like to hide the whole header control.
-eric
Hello Eric,
Thank you for your feedback. I am glad that you resolved your issue and I believe that other community members may benefit from this as well. Also You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
There are many benefits to submitting an product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thanks for the info. I did eventually get this to work but in the end I went a different direction. It might be a nice little feature if the Expander had a boolean property HideHeader. Thanks.
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I copied the default Style of the Expander and added a Trigger to hide the Rectangle that contains the Header if the Header Property of the Expander is not set. Please let me know if this helps you or you need further assistance on this matter.
