Good Morning! I’m seeing an issue with my xamOrgChart and I’m hoping you can help. I’m using the xamOrgChart to display hierarchical charges. Most of the charges are just a few levels deep and work fine. A few of the charges have a lot of levels to expand. As I’m expanding levels at the bottom of the org chart I can see the overview pane changing to include the new nodes, but at some point (it seems about the same amount of space every time) this does not happen. The org chart shown in the overview pane expands horizontally, but I can’t see the new nodes added at the bottom. I can see my viewing area circled in the overview pane and as soon as I pan or zoom my area below the overview showing to the new nodes, the whole org chart “disappears”. All I see is the white background. I can zoom or pan to get it back, but if I have a lot of child nodes below the overview pane it is hard to move around and see things how I really want to. Every time you pan or zoom it disappears again.
Do you have any ideas what could be causing this? Is there some kind of “max height” the org chart can be that I’m unaware of? The orgchart exists inside a Grid where RowDefinition = *.
Thank you!
Hi Hitesh,
This issue was resolved in a service patch 2 years ago. What version of the Infragistics product are you using? The fix should be available in the latest version of 13.2 or above.
Hi Alicia,
did you get resolution for your above issues? I am also facing somehow similar issue. I have several childs under 1 node and xamorgchart shows just 1 line if node have 100+ childs. have too zoom and scroll mouse quiet long to see the proper nodes.
Regards
Hitesh
Hello Alicia,
I was able to reproduce the issue that you described. I created a hierarchy of nodes 10 levels deep and around the 5th or 6th level during expansion, it stops adding the nodes to the overview pane. After this occurs and I expand a few more levels, I do notice that as I pan down a bit, the nodes disappear. I believe this has something to do with the nodes not appearing in the overview pane.
Since I was able to reproduce the issue, I've asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 170228. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I have also created a private case for you so that you may view the status of the development issue. You can view the status by selecting the "Development Issues" tab when viewing this case on the website. The case number is CAS-135141-N5F9C0.
Hi Rob, Below are the settings I have on my xamOrgChart. It seems that the nodes stop appearing in the overview pane at about level 5, but the zoom/pan doesn’t become a real issue until levels 6/7 when most of the nodes are out of the overview pane.
Grid.Row="0"
Grid.Column="1"
NodeArrangementStrategy="Stagger"
NodeControlAttachedEvent="uiOrgChart_NodeControlAttachedEvent"
SelectionType="Multiple"
SelectedNodesCollectionChanged="uiOrgChart_SelectedNodesChanged"
LevelsToExpand="1"
InitialTreeDepth="3"
MaximumZoomLevel="1.5"
IsEnabled="{Binding AreResultsInvalid, Converter={StaticResource Ems.Converters.BooleanInverseConverter}}"
NodeStyle="{StaticResource NodeStyle}">
I'm putting together a sample to try and reproduce this Just a few questions to help me... Do you know how many levels deep your org chart is? Is the last expanded level where the overview pane stops updating always consistent?
I will get back to you shortly once the sample is finished.
