960
XamPropertyGrid and Collection...
Hi, I'm developing a system that uses the new XamPropertyGrid  to visualize (and I'm thinking also to edit if possible) the details of some classes
some of the classes have the following format
MyProperty1
Myproperty2
MyCollection1
     Element1
     Element2
     Element3
The Mycollection1 is correctly shown but its elements are shown in the following format
[0]
     ElementProperty1
     ElementProperty2
The collection elements in my case are objects containing a Name and a Value and are Dynamically created on the objects.
Is there a Way to tell the Property Grid to show (maybe the ToString) instead of the [0] so that the effect will be more User friendly?
I make an example: The Object is  a Project, The Collection is an accessory information data the content of the property grid I'd like to have is the following:
     ProjectName StarTrek
     FileName StarTrek.proj
     Folder C:\Startrek
     Revision 1.0
+   AdditionalInfo
          + Order 12345
                Name Order
                Value 12345
          + DeliveryDate 06/01/2015
                Name DeliveryDate
                Value 06/01/2015
This will allow to use the property grid in several scenarios and avoid the need to develop a specific User control or window to visualize the data and modify them.
Thank you in advance
