Is it possible to add a new record in GroupBy View of the UltraGrid (wingrid)? I've a situation where I'm recording some financial Trades in the grid. Each Trade has a Market Number. In one view, I want to show Trades grouped by Market. If the Market exists, I should be able to add a new Trade in that Market. If I have to enter a trade for a new Market, I should be able to do that as well.
Sorting and grouping are related since it must sort to do a groupby.
That worked great! Thanks!
I just wonder why the groupping is set into the sortedColumns...
You can do a "Group By" programatically...
ultraGrid1.DisplayLayout.Bands[0].SortedColumns.Add("ColumnName", false, true);
where you need to replace "ColumnName" by the "Clients" column in your case... whatever be the real name of the column.
Oh, I'm sorry... I think I misunderstood the subject of this conversation... What I'm looking for is a way of setting programmaticaly a column as GroupBy.
For instance, if I click the "By clients" button group all by clients, instead of having to drag the Clients column into the group by box.
Thanks!
Mariano.
I did a small "work around" to get this functionality... You could probably try that if it satisfies your requirement.... This is what I did:
