105
Installing Win Forms application from UNC path
We are using the UltraGrid in a win forms application that is distributed through a UNC path.
When we publish the application, and the user tries to run it we get the error: The application requires that assembly Infragistics2.Win.Misc.v12.1 version 12.1.20.21.2071 be installed in the Global Assembly Cache (GAC) first.
Because this is a corporate application, running a seperate instal on everyones PC that might someday get this application is unreasonable. How do I get the library to install from the publish wizard.
Thank you
Andre
Parents
  • 53790
    Verified Answer
    Hello Andre,
    If I understand well your issue, one possible reasons to get the error "The application requires that assembly Infragistics2.Win....." after publish your application, could be if you didn`t distribute infragistics assemblies that you are using into your application.  To solve this problem you should explicitly set "PublishStatus" to be "Include" for these assemblies.
    I already was able to reproduce this scenario at a two different machine. The first one (my machine) has Infragisitcs assemblies and the second one is without Infragistics assemblies. When I set "Publish Status" = "Include" I was able to run the sample at the second machine, otherwise I get the same error that you describe in your first post.
    Please take a look at the atatched screenshot and video file and let me know if you have any questions.
    Regards
Reply Children
