15
Error when updating or installing Infragistics Ultimate 17.2
I am having an issue when trying to either update or install/repair Infragistics Ultimate 17.2
On anything I try I run into the following messages:
Version Utility: An error occured during download, please check internet connection and retry again.
Visual Studio Extension: An error occured during download, please check internet connection and retry again.
Visual Studio Template Gallery: An error occured during download, please check internet connection and retry again.
Any help would be appreciated.
    I am facing the same issue
      Offline posted in reply to Julia tom
      Was a response received?
        Offline posted in reply to sreelaxmi siripurapu
        got it resolved. it was failing to create virtual directory.I had to set the windows feature under IIS-> II6 management compatibility and then it installed fine.
          Offline posted in reply to Rikardo Milio
          I am having issue installing netadvantage ASPNET 2008 Vol1 CLR20 on my Windows 10 machine as well. it just does a rollback and end the installation after a while.not seeing any errors in log file.i am seeing "infragistics assembly install: failing at removedirectoryandchildren" for each assembly in log file.not sure what that means. any help would be appreciated.
      • 7575
        Hello Jason,
        Thank you for posting to our forum .
        Would like to know are you installing with the Platform Installer? The Platform Installer will encounter an error if it cannot download the MSI files to install Infragistics because it is blocked by a firewall or a proxy, or if it fails to connect for some reason.
        If you are using a registered product, please try downloading the Complete Bundle instead. The Complete Bundle can be found on the Account Info page. Select your product version from the list, then choose Complete Bundle.
        Please let me know if this does solve the issue.
        • 15
          Offline posted in reply to Divya Jain
          I am using the Platform installer. And it is a firewall issue, is there a list of URLs to whitelist on our firewall?
          • 7575
            Offline posted in reply to Jason Stearns
            Hello Jason,
            Thank you for the update.
            The Platform Installer fetches the installers from "dl.infragistics.com" so you should be able to have this whitelisted.
            Please let me know if you need further assistance.
