70
Export igHierarchical Grid to excel using ig.Excel
We had a requirement in our project to export the IG Hierarchical grid data to excel worksheet with grouping. I found from the forum that IgniteUI JQuery control currently does not support export to excel for igHierarchical grid. Hence, I have created my own method to export the grid to excel. So, far I have got it working where I see the parent grid and child grid in the excel file. However, I also need the grouping indicator to expand/collapse the child grid rows. I tried using the ig.Excel.RowColumnBase class's method outlineLevel() and ie.excel.DisplayOptions class's showExpansionIndicatorBelowGroupedRows but none them are producing the required result.  Below is my excel export method...
function exportToExcel() {
var workbook = new $.ig.excel.Workbook($.ig.excel.WorkbookFormat.excel2007);
                var worksheet = workbook.worksheets().add('Sheet1');
                //var displayOptions = new $.ig.excel.DisplayOptions().showExpansionIndicatorBelowGroupedRows(true);
               // worksheet.displayOptions. = displayOptions;
                var rowBase = new $.ig.excel.RowColumnBase();
                var xlRowIndex = 0;
                var headersTable = $("#igdataGrid").igGrid("headersTable")[0];
                for (var headerRowIndex = 0;
                headerRowIndex < headersTable.rows.length - 2;
                headerRowIndex++, xlRowIndex++) {
                    var headerRow = headersTable.rows[headerRowIndex];
                    var xlHeaderRow = worksheet.rows(xlRowIndex);
                    var computedStyle = window.getComputedStyle(headerRow);
                    var xlColorInfo = new $.ig.excel.WorkbookColorInfo(computedStyle.color);
                    xlHeaderRow.cellFormat().font().colorInfo(xlColorInfo);
                    for (var headerCellIndex = 0;
                    headerCellIndex < headerRow.cells.length;
                    headerCellIndex++) {
                        var headerCell = headerRow.cells[headerCellIndex];
                        worksheet.columns(headerCellIndex).setWidth(
                        headerCell.offsetWidth, $.ig.excel.WorksheetColumnWidthUnit.pixel);
                        var xlHeaderCell = xlHeaderRow.cells(headerCellIndex);
                        var computedStyle = window.getComputedStyle(headerCell);
                        xlHeaderCell.cellFormat().fill(
                        $.ig.excel.CellFill.createSolidFill(computedStyle.backgroundColor));
                        xlHeaderCell.value($(headerCell).text());
                var rows = $("#igdataGrid").igGrid("rows");
                var childGridTable, childHeaderRow;
                for (var dataRowIndex = 0;
                dataRowIndex < rows.length;
                dataRowIndex++, xlRowIndex++) {
                    var dataRow = rows[dataRowIndex];
                    var xlRow = worksheet.rows(xlRowIndex);
                    rowBase.index = xlRowIndex;                      rowBase.outlineLevel(1);
                    for (var dataCellIndex = 0;
                    dataCellIndex < dataRow.cells.length;
                    dataCellIndex++) {
                        var dataCell = dataRow.cells[dataCellIndex];
                        xlRow.setCellValue(dataCellIndex, $(dataCell).text());
                    //expand the first child grid to get the headers name.
                    var parentGrid = $("#igdataGrid").igHierarchicalGrid("rootWidget"),
                        rowDomElement = parentGrid.rowAt(dataRowIndex);
                    $("#igdataGrid").igHierarchicalGrid("expand", rowDomElement);
                    childGridTable = $("#igdataGrid").igHierarchicalGrid("allChildren")[dataRowIndex];
                    //childHeaderRow = childHeadersTable.find("thead").find('span.ui-iggrid-headertext');
                    //extract all the childgrid data
                    //var childRows = $("#igdataGrid").find("table[data-childgrid=true]").data().igGrid.dataSource.data();
                    //$.ig.excel.DisplayOptions.showExpansionIndicatorBelowGroupedRows(true);
                    var childHeadersTable = $(childGridTable).igGrid("headersTable")[0];
                    childRows = $(childGridTable).igGrid("rows");
                    if (childRows.length > 0) {
                        xlRowIndex++;
                        //write the child header row
                        var headerRow = childHeadersTable.rows[0];
                         rowBase.index = xlRowIndex;                          rowBase.outlineLevel(2);
                            //worksheet.columns(headerCellIndex + 1).setWidth(
                            //headerCell.offsetWidth, $.ig.excel.WorksheetColumnWidthUnit.pixel);
                            var xlHeaderCell = xlHeaderRow.cells(headerCellIndex + 1);
                        xlRowIndex++;
                        for (var index = 0;
                            index < childRows.length;
                            index++, xlRowIndex++) {
                            var childRow = childRows[index];
                            for (var childGridCellIndex = 0;
                            childGridCellIndex < childRow.cells.length;
                            childGridCellIndex++) {
                                var dataCell = childRow.cells[childGridCellIndex];
                                xlRow.setCellValue(childGridCellIndex + 1, $(dataCell).text());
                    $("#igdataGrid").igHierarchicalGrid("collapse", rowDomElement);
                workbook.save({ type: 'blob' }, function (data) {
                    saveAs(data, "igGrid.xlsx");
                }, function (error) {
                    alert('Error exporting: : ' + error);
I would really appreciate your help on this.
Thanks.
  • 16310
    Suggested Answer
    Hi Sireh,
    It should be enough to just use xlRow.outlineLevel(indent) where indent = 1 for the first level child bands and increase it for every next hierarchy level. Anyway, you are working with the grid DOM and this is causing some issues - for example in the for loops where you refer the datacell the first cell in the <tr> is empty ( in the grid it contains only expand indicators). I suggest that you do not work with these, so you may modify your for loops to look like:
                        dataCellIndex < dataRow.cells.length - 1;
                        dataCellIndex++) {
                            var dataCell = dataRow.cells[dataCellIndex+1];
    I have modified your sample and the exported sheet have expanding indicators that work. It needs further improving, but I did not want to hold the response so I'm sending you my progress so far. Please let me know if the result is ok and if so the approach can be further modified so that the child grid headers could be collapsed too.
    ighier.zip
    • 70
      Verified Answer
      Offline posted in reply to Hristo Anastasov
      Hi Hristo,
      Thanks for your help. I was able to export using your modified code.  As you already mentioned there were few issues with the code. Here is the modified version.
      function exportGrid() {
                      //$.ig.GridExcelExporter.export($("#igdataGrid"), { fileName: "Manage_Generator_Mapping" }, {
                      //    rowExported: function (sender, args) {
                      //var rowBase = new $.ig.excel.RowColumnBase();
                      var xlRowIndex = 0;
                          headerCellIndex < headerRow.cells.length-1;
                              var headerCell = headerRow.cells[headerCellIndex + 1];
                          //rowBase.index = xlRowIndex;
                          //rowBase.outlineLevel(1);
                          xlRow.outlineLevel(0);
                          dataCellIndex < dataRow.cells.length-1;
                          dataCellIndex++) {
                              xlRowIndex++;
                              //rowBase.outlineLevel(2);
                              xlHeaderRow.outlineLevel(1);
                              xlRowIndex++;
                              for (var index = 0;
                                  xlRow.outlineLevel(1);
                          saveAs(data, "Manage_Generator_Mapping.xlsx");
      • 70
        Offline posted in reply to Hiren shah
        Never mind, I found the solution. It was the script manager which was causing this.
        • 70
          I made changes suggested by you and it worked on one page. But on the other page where I have same hierarchical grid, it is throwing some exception on
          var worksheet = workbook.worksheets().add('Sheet1');  //Error on this line -- Uncaught Sys.ParameterCountException: Sys.ParameterCountException: Parameter count mismatch.
          Please help me out here.
          Hiren.
          • 16310
            Thank you for your feedback, I am glad you have managed to resolve your issue. Please let me know if I may be of any further assistance to you.
